Ihr letzter Besuch: So Mai 11, 2025 10:56 Aktuelle Zeit: So Mai 11, 2025 10:56
 [ 6 Beiträge ]
 Betreff des Beitrags: Grundig 3192
BeitragVerfasst: Mi Feb 05, 2020 3:24
I have a Grundig 3192 which has a frozen balance control . I am trying to dismantle the control in order to get inside and work on it. The attached photos show what I have. The balance control is stacked with the two volume controls. There is a piece on the end of the volume control shaft that has a pin it. I removed the pin but the end piece will not come off. This piece is preventing the balance control assembly from being removed. My question is " Should the end piece on the volume control just slide off or does it unscrew clockwise or counter-clockwise?". It may also be frozen to the shaft.
 Betreff des Beitrags: Re: Grundig 3192
BeitragVerfasst: Mi Feb 05, 2020 11:24
Bewegt sich die sekundäre Achse überhaupt?
Ich hatte ein ähnliches Problem mit meinem Grundig 4077, aber es war die Sekundärachse, die die Ferritantenne bewegte.
In meinem Fall gab es einen Schaden durch die Steuerknöpfe. Ich musste die Achsen mit feinem Sandpapier abschleifen und etwas Leichtöl auftragen.
Ich hoffe, das hilft, und es tut mir leid, wenn ein Wort falsch ist. Ich arbeite immer noch an meinem Deutsch.
-Freundliche Grüße,
-Zach
BeitragVerfasst: Mi Feb 05, 2020 13:34
Thanks. I don't speak German either. I posted this in English. It is the secondary that is frozen. That turns the balance control. I suppose that I will have to rely on a product I have called " Liquid Wrench" to loosen up the control.
BeitragVerfasst: Mi Feb 05, 2020 14:42
Problem solved. For future reference in case others come across the same problem. I loosened up the control by applying heat with a hair dryer for a few minutes. I was able to turn it CW and CCW and it is now usable.
BeitragVerfasst: Mi Feb 05, 2020 16:23
John-Jarratt hat geschrieben:
Hah good to know. I did not even realize it was in English, as I have Chrome set to auto translate.
Yes, some heat will loosen up frozen pots, but be warned, once it cools off again it can seize back up. However if you are disassembling the pot you should be ok.
-Freundliche Grüße,
-Zach
BeitragVerfasst: Mi Feb 05, 2020 23:00
John,
don't forget to wash out the space between the parts with a solvent, like gasoline or WD 40 and then relubricate it with a good oil to prevent the whole thing from sticking again!
BR, Stefan
 [ 6 Beiträge ]
