Hello,
recently I bought this nice model. Yesterday it came by mail, today I took some pictures. The condition was much better than I expected, as it turned out, except added DIN socket, this radio haven't seen a soldering iron outside a factory! Everything is in place, solder points colored, even dial lamps are original, signed by RFT. Unfortunately, beautiful AZ12 has one cathode broken...
The radio is enormous, a little bigger than Amati.
How often do you find a radio in such condition inside?
Do you think I should get it running?
I'm slowly convinced, I shouldn't repair it - as usual I'd have to replace many of that poor tar capacitors, and it wouldn't be as original anymore... I have enough working radios, so it's not so necessary, on the other hand, I didn't heard radio with EL12.
Too bad the case needs new coat of laquer - old one you can scratch with your fingernail.
I wonder, did anyone see a version with Gnomrohren? Even on Radiomuseum there's nothing...
PS. I hope everything is correct with pictures.
Regards,
