Itt pinto radio https://www.dampfradioforum.de/viewtopic.php?f=69&t=33391 |
Seite 1 von 1 |
Autor: | inecik [ Di Mai 30, 2023 9:21 ] |
Betreff des Beitrags: | Itt pinto radio |
Hi I have a ITT pinto radio, just now,my radio is working very well but I have a question, I adjust the radio station but When I move away from the radio , the tuning is distorted. |
Autor: | inecik [ Fr Jun 02, 2023 7:46 ] |
Betreff des Beitrags: | Re: Itt pinto radio |
Hi, is there anyone !!!! |
Autor: | Der Hesse [ Fr Jun 02, 2023 8:30 ] |
Hei there, du you have an antenna conectet? If not then you are the antenna ![]() Or is this radio a portable? Then it is possible that you must adjust the direction of the antenna. |
Autor: | berndw [ Fr Jun 02, 2023 10:04 ] |
Hi Mr. Unknown / Mr. Impatient, can we assume this the radio you are talking about? https://www.radiomuseum.org/r/itt_pinto.html If yes, then tell us: - is the problem on FM or AM? - is the FM antenna at full length? - have you checked the connection between PCB and FM (telescopic) antenna? Best regards, Bernd |
Autor: | inecik [ So Jun 04, 2023 6:55 ] |
Hi, this radio is a portable radio and have 70cm antenna and my problem is on fm.the antenna connection is okey. |
Autor: | Der Hesse [ Fr Sep 15, 2023 8:26 ] |
Hi, did you find the problem? |
