UHER Variocord 263 hilfe bitte!
Mark128
Beitrag von Mark128 »
Dear friends,
Excuse me for writing in English. I'm from Cyprus. My grandfather had this perfect tape recorder, UHER Variocord 263. I recently pulled it out of the attic and found that it works great: everything is spinning and glowing, just the sound is “dull”. An expert told me that playback head replacement is needed. I searched the whole eBay and didn't find any 4 track heads for replacement. That is, the device is working, but not as it should. And there are a lot of records on reels. Please, help me: where can I buy such a head, or at least tell me its technical specifications for replacement in order to choose a similar one in measurements and data. I really want to fix this UHER. :!:
Thank you in advance!
Re: UHER Variocord 263 hilfe bitte!
Beitrag von hoeberlin »
Hello, Mark,
These Uher Tape Recorders have the Heads mounted to the Heads Cover, which is held in Place by 2 Srews on the Top.
By loosening the Screws You can pull up and remove the whole Head Assembly.
You schould check, if the Head is clean. If clean, then you schould look, if the head Surface looks worn out and uneven.
Maybe You can make a Foto of the Head Surface, and post here.
There are also many Chances that the Amplifier is not working perfect, and this is the Cause of the poor Sound.
Hope this helps.
Best Regards from Berlin/Germany,
Henning
Gerufon
Derzeit abwesend
Beitrag von Gerufon »
Hi Mark,
I think you should also try https://forum2.magnetofon.de/
There are some "native Uher's" there,
even a guy who worked in the UHER research-and Development departement. :hello:
[b]Bitte beachten: Meine Beiträge könnten Spuren von Ironie und Sarkasmus enthalten. Als Gegenmittel empfehle ich eine nach abwärts gerichtete Kellertreppe.[/b]
Schorse
Beitrag von Schorse »
I assume, that the expert did clean and demagnetize the heads first?
Schorse
Klarzeichner
Beitrag von Klarzeichner »
Clean, first of all, clean!!
BR Stefan
