lembeck radio schema
inecik
Beitrag von inecik »
dear friends I am from TURKEY.I have a lembeck radio( europa-export type 122 .this radio is same with lembeck europa W for me).I need a schema because radio hasn't 2 tube.there are 6 tube in the radio,EBF80 EBC41 EF40 ECH42 EL41 EM4. I want to learn another tubes names.another questıon: there is a part it is looking like a capacitor and this part has this label; 250/109 LB. is it a selenium rectifier?
Thorben
Beitrag von Thorben »
Dear inecik,
You're right. This part with the label 250/109 seems to be a selenium rectifier. Most of them were produced by the german company "Siemens".
What do you mean with learning new tube types/names?
I guess your looking for the missing tubes in your Radio, don't you?
There is a site on the internet.
http://www.radiomuseum.org/
You can choose English as language there, too ;)
Have a look at this site and report us if you're radio is there.
The tubes in your radio are older ones. I guess it's a radio older than 1955.
Greets,
Thorben
inecik
my radio must have 8 tube but NOW this radio have 6 tube, there aren't 2 tube in the radio and I don't know these tubes names.so I need a circuıt schema. I know that cite, www.radiomuseum.org. I looked in this site for my radio but there is no my radio model but I think like my radio with lembeck europa W type.
inecik
my radio picture
inecik
radio picture
Thorben
Dear inecik,
I'm sorry that I can't help you easily now. The radio company "Lembeck" is not really known in Germany, seems that they never produced many radios. That doesn't mean that Lembeck is not a good company.
I think it's nearly impossible to find the schema for your Radio.
But there could be a good solution for your problem.
Could you please take a photo of the interior? Some tubes you have listed are really rar. I guess one tube you're looking for is the tube for VHF (in german UKW, VHF=very high frequenzy, german=Ultra Kurze Welle)
If you take a photo of the interior we might have a chance to guess what tube is missing.
I will translate your answers in german, maybe some of the others could help you, but doesn't understand english ;)
Greets,
Thorben
Also für die anderen. Dieser türkische Herr sucht das Schaltschema oder zumindest die Röhrenbestückung für sein Lembeckradio.
Im rm.org findet er leider nichts dazu.
In seinem Radio fehlen 2 Röhren. 6 sind noch drinne:EBF80, EBC41, EF40 ECH42, EL41 und EM4.
Vielleicht weiß einer von euch, welche Röhren da noch fehlen könnten.
Es scheint so als würde die Röhre für UKW fehlen, falls dieses Radio überhaupt schon UKW hat, denn die Röhren sehen schon recht alt aus. Vermutlich ist es ein Radio, das kurz nach dem 2. Weltkrieg gebaut wurde.
Thorben
inecik
dear sir I can send you pictures tomorrow.
radiobastler
Beitrag von radiobastler »
Hallo Thorben,
bei mir hapert es mit dem Englischen ein wenig, aber ich habe etwas gefunden. Im Radiomuseum stand folgendes:
http://www.radiomuseum.org/dsp_herstell ... any_id=429
und weiter verlinkt dieses hier:
http://www.radiomuseum.org/m/lembeck_d_ ... dex_1.html
vielleicht könnt ihr damit etwas anfangen.
p.s. Die Funkschau die auf der Seite erwähnt wird gibs hier:
http://www.radiomuseum.org/forumdata/us ... v1_v11.pdf
Zuletzt geändert von radiobastler am Mi Sep 30, 2009 17:18, insgesamt 1-mal geändert.
Gruß Stephan
Röhre gut, alles gut
ich bezweifle ein UKW Empfangsteil.
Bei den gelisteten Modellen in rm sind diese beiden am ähnlichsten. Auch die Optik (das halbe Bild) lassen ein Europa Modell vermuten. Evtl. wurde mal eine EB41 zur EBC41 umverdrahtet.
vorhanden: ECH42 EBF80 EF40 EBC41 EL41 EM4
Europa 652W: ECH42 EBF80 EF42 EQ80 EL41 AZ41 EM4
Europa 681W: ECH43 EBF80 EF40 EF42 EB41 EL41 EM4
Thorben
Gut dann berichte ich mal ;)
Hier aber dann erstmal ein Dankeschön, dass ihr fleißig mitgesucht habt.
Dear inecik,
You see, two of our members tried to find your radio on radiomuseum.org .
You also see, that there are differents between the german name of your radio and the name for the export of your radio.
We think that you could have got this modell:
http://www.radiomuseum.org/r/lembeck_eu ... 652gw.html
It looks like the one of your photo. (we only can see the upper half of the picture)
So in german your radio is called: Europa 652W or Europa 681W
There is only one problem, the tubes in your radio may not be original.
Have a look on the tubes of these two modells:
The member "saarfranzose" thinks, that your radio could have been repaired some time ago, so that the tube EB41 was changed into a EBC41, what really could be possible. There aren't many differents between the two tubes. I for my part think, that the EBC41 is easier to buy today.
I hope we could help you a bit 'till now. Maybe your photo tomorrow could help us. Is it okay, if I post that picture into this threat? I see you have problems with the upload.
Greets,
Thorben
Also, ich habe ihm jetzt gesagt, was ihr gesagt habt.
Dass es also möglich ist, dass diese EB41 in eine EBC41 umgetauscht wurde und das sein Radio vermutlich eins dieser Europa's ist ;)
Thorben
inecik
radio picture is inside
ich glaube in der Briefmarke 5 Tasten zu erkennen. Damit fällt der 652W weg. Vom 681W gibt es keine Vergleichsbilder, dafür aber eine Schaltung bei rm.
inecik
dear PL504 my radio have total 8 tube,652 and 681W have total 7 tube and my radio have a seleniom rectifier( 250/ 109 LB) so a rectifier tube( AZ41) musn't be in my radio.is it O.K
inecik
I think that: my radio is a EUROPA W 1952 type , so everyone have a schema this radio( lembeck europaW 1952.....http://www.radiomuseum.org/r/lembeck_europa_w_neu.html
Die 5 Tasten müssen dann zu den Klangregistern gehören.
