philetta B2D33A radio
inecik
Beitrag von inecik »
hello,I have a radio philetta B2D33A but there is no sound.all of valves are light and I replacemend filter caps and two non electrolıtic caps. and ECC85 valve has much hot,is it normal? ECL86 valve's anot has 200 VDC(pin no 6) and pin no 9 has 75 VDC.
Rocco11
† Siemens D-Zug
† Siemens D-Zug
Beitrag von Rocco11 »
Hello,
the voltages could be OK. Unfortunately I got no service manual.
What happens when you put a signal to the TA-connector (Pick-Up)? Is then any noise or sound from the speaker? At first, you must be shure that the Audio-Frequency circuit is working.
Greetings
Rocco11
Mr. Woodenapple
Beitrag von Mr. Woodenapple »
I uploaded the schematic for you HERE, hope it helps!
Christian
Niels
Beitrag von Niels »
you could check the noise, if you pull out a tube. Go systematically from the UKW terminal (with the ECC85) to the preamplifier/power amplifier (ECL86). Perhaps the voltages in the ZF(EBF89), for example on the grid are not right. I had such a problem a few years before.
Niels
Ich freue mich immer über nette Gästebucheinträge unter http://www.roehrenseiten.de
