* SPAM-Verdacht! Werbung nicht erlaubt* Diablo 4: Solve the Brazier Puzzle
AventurineLe
Beitrag von AventurineLe »
After agreeing to help Gelena, one of the witches of the coven, you'll be transported to a ritual site in front of Diablo 4 Gold the Tree of Whispers. The area is adorned with a magical circle and three braziers, each with a coven member standing beside it.
Gelena will begin the ritual by instructing you to “Invoke the tree's forgotten name.” Pay close attention to the words spoken by the witches as the ritual starts. These words are key to solving the brazier puzzle.
Step 2: Solve the Brazier Puzzle
The brazier puzzle is the first challenge in the quest. During the ritual, each coven member will chant a word:
Ayh
Yew
Oun
To invoke the forgotten name of the tree, you need to light the braziers in the same order the words were spoken. Here's the correct sequence:
Ayh – Light the left brazier.
Yew – Light the right brazier.
Oun – Light the top brazier.
Be careful not to light the braziers out of order, as this can disrupt the ritual and force you to buy Diablo 4 Gold start over.
Step 3: Draw the Ritual Circle with Nangari Blood
Once you've lit the braziers in the correct order, Nangari Blood will drop onto the ground. You'll need to pick it up to Diablo 4 Gold proceed with the ritual.
Next, you'll be tasked with drawing the ritual circle. This step can be a bit tricky but is straightforward once you get the hang of it:
Slowly walk around the outer edge of the circle.
As you move, small blood explosions will fire off, sketching the ritual circle.
Patience is key here—don't rush, as moving too quickly may cause the process to reset. Once the circle is fully drawn, the next phase of the ritual begins.
Step 4: Defend the Ritual Circle
With the ritual circle complete, enemies will start spawning. Your job is to buy Diablo 4 Gold defend the circle against waves of Headrotten and other monsters.
Tips for Success:
AoE Abilities: Use area-of-effect skills to quickly clear groups of Diablo 4 Gold enemies and prevent them from overwhelming you.
Crowd Control: Skills that slow, freeze, or stun enemies can buy you time and keep the circle intact.
Manage Resources: Keep an eye on your * SPAM-Verdacht! Werbung nicht erlaubt* potions and energy resources to cheap Diablo 4 Gold ensure you're ready for tougher enemies.
Completing this phase successfully will finish the ritual and the quest.
