ECL86 valve question
inecik
dear friends I have a philps philetta radio and the radio has ECL86 valve but this valve is missing in my radio.I didn't find a new ECL86, I have a lot of another valves ,now my question; can I replacement a ECL86 with another valves ( for example EL84,EL 34 etc.)
Funkschrotti
Hello,
the replacement of a ECL86 by other tubes is not possible or needs to much changes in the radio. There are many internet shops where you can buy new ECL86 for medium prices.
The only other tube which is possible, is the PCL86 from old TV instead of a ECL86, but for the PCL86 you need nearly 16 volts for the filament (ECL86 has a 6,3 volt filament).
Best regards,
Roland
Best regards,
Roland
inecik
Radiomann
- † Siemens D-Zug
Hello inecik,
here you can order an ECL86:
http://stores.shop.ebay.de/TubeProfi-Sh ... mit=Finden
It's rather expensive, but it seems that the tube is new (NOS).
Greetings
Greetings
inecik
Radiomann
- † Siemens D-Zug
Jean_Berlin
you can try voltage-doubling (DC from AC) as described here:
http://www.b-kainka.de/bastel89.htm
Burkhard shows on the bottom of his story how to make 50 Volts DC from 24 Volts AC. This will work with 6,3 to about 14 Volts as well. You will only need two diodes and two caps.
Best Regards,
Jean
Best Regards,
Jean
keerborstel
Hello inecik
you can use also a small additional transformer, with secondary 12V 0.3A , this will work for heating the PCL86. Disconnect the 2 pins No. 4 and No. 5
from the 6.3V heating circuit, and connect 12V to the pins. Do not forget to connect one pin of the 12V to ground. Thats it.
Best Regards Armin
Best Regards Armin
Zuletzt geändert von keerborstel am Do Nov 12, 2009 7:39, insgesamt 1-mal geändert.
- † Siemens D-Zug
keerborstel
- † Siemens D-Zug
Eisenkern
So ein kleines Päcken kann per Einschreiben verschickt werden, nennt sich wohl dann Briefsendung ist aber trotzdem ein Päckchen.
Kostet um die 13 Euro mit DHL.
Falls DHL nicht die Preise geändert hat, sollte es also kein Problem sein.
Man muss den Verkäufer nur auf diese Möglichkeit hinweisen.
Gruss Eisenkern
Gruss Eisenkern
yehti
